FYI Newmar 2024 DPDS slide out routine
Joe Dutchstar
Florida
Dutch Star 4311
Cummins
2018 Ford Flex
Surprisingly, after reading the User Manual on the proper slide out and leveling jack routines, (after 2 years of ownership) the slides should be extended when at ride height without the jacks extended.
After the slides are out and stable then extend the stabilizing jacks.
This is routine described in the User Manual starting at page 246.
I thinks it’s been this way since the FWS was starting being used…
That works if you are on ground thats close to being level. If not near level, I check all the slide out corners so not touching anything. They say thats how there built on chassis with air, But their building is perfectly flat.
Agreed….we always check the “reveal”, which is the gap along the FWS to ensure it is pretty close to even up and down before deploying.
Same on our Superstar.
They do add a caveat about checking the reveal (and as mentioned if not on level ground) to try putting jacks down to level then do the slides - at least in our manual it is written that way.
Newmar diesels have been like this since about 2015. Always surprised when this topic comes up weekly one place or another.
The theory is they are installed while sitting on factory suspension, not hyd jacks.
Yes there are several points in the user manual on checking the reveal around the slide outs and surrounding area for obstruction.
We do not have FWS but intend to follow the mfg process going forward.
In talking with a Newmar engineer at the Tampa show a few years ago, he said if the ground is relatively flat with no issues to twist the chassis, you can deploy or store the slides with no problem on suspension or dumped. Our pad behind the house is flat but sloped to one side and to the rear (1" in 10' and 1" in 45') to help with drainage away from the house and I move the slides in and out with the suspension dumped with no issues. I agree the best way to test is check the reveal. If the chassis has a twist, it will show up there.
In my opinion, you can move the slides (it's really just about the FWS) anytime jacks are not down (or not air leveled). Jacks could cause the twist and the issue.
What do you do on a site that is not level?
It is important to check the slide edge reveal prior to moving slides. If there is a bind then deploy jacks or look for a more level position.
