Trim piece
Bonron2
Hi all, I have a 2016 coachmen pursuit 27kb. The 1” trim piece that goes around the rig is starting to fail and fall off. Does anyone now what the part number might be and where I can get a replacement roll. Thanks.
If you are describing the vinyl molding coming loose, you can carefully remove what is left hanging. Remove the adhesive and clean the strip. You can the purchase some "two sided tape" https://www.amazon.ca/s?k=two+sided...s,216&ref=nb_sb_ss_ts-doa-p_4_14&tag=rvf01-20 and reuse the existing molding. Just make sure that you also clean the coach surface where the molding attaches. It can be a tricky job. If you don't feel comfortable doing it most detail shops will help you out. This will be a lot less expensive than replacing the molding. FYI Don't use glue to restick it. It just makes a mess.
