porterstoy
- Oct 2, 2025
No, I used the Sleep Numbers mattress that came with the coach. Here are some pics.Good to know! Thank you so much. Are you also using the Axle Bloom mattress with it?
Yes I did go to stronger struts. And just know, it really raises the bed, by 3" so you need to make sure you will be OK when the slides are retracted. I actually modified the base (Huge project) to lower it.Looks nice ! Did you have to change struts for the added weight?
Thanks again for the info. Looks comfy!No, I used the Sleep Numbers mattress that came with the coach. Here are some pics.
