Does the metal box enclosing the heat exchanger under the seat get hot during normal operation?I believe that valve shuts off engine coolant to the small heat exchanger under the seat. Ours is on all the time.
Yes, when the engine is running, hot engine coolant circulates through a small, (but very efficient) heat exchanger under the seat. So yes, warm is normalDoes the metal box enclosing the heat exchanger under the seat get hot during normal operation?
Thank you for the explanation. Now I wonder, what’s the purpose of this arrangement?Yes, when the engine is running, hot engine coolant circulates through a small, (but very efficient) heat exchanger under the seat. So yes, warm is normal
Amazing! Thank you.This allows heat from the engine to supply heat to the Alde for cabin heating and also heats the water for showering etc. This allows you to have heat and hot water without using propane or being plugged in to shore power.
