Hot water pilot wont stay lit
hutch
2017 Windsport. Having trouble keeping the hot water tank lit. Book says it cant be lit manually so i just keep flipping the switch and hope for the best. Sometimes get lucky other times it goes out after a few minutes. Flame looks good and blue. Anyone have a video on how and what to clean? Is bad propane a thing? i fill at my families business and have had family members say their grill at home does the same thing. Seems like an odd coincidence.
I would have a tech look at it if you are not comfortable working on it. It could be a few different things. A bad thermocouple, dirty burner tube, dirty igniter. It can also be low pressure.
The striker electrode may need cleaning or replacement. I don't think it has a thermocouple.
Does it stay on long enough to warm the water?
Is it blowing out due to wind?
When its acting up wont stay on long enough to heat, other times its fine for the day. Don't think wind is an issue getting behind the panel.
Clean or replace the electrode. That item senses the flame.
Beyond that Clean the tube of any spider webs, and check the wires for damage.
No wind i believe, Sometimes it will stay on long enough to heat the water but usually not.
My Forest River TT does that occasionally ..I use compressed air to blow everything clean..its starts working again..so far at least..I think rust from non regular use is the problem
