Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
NoNoticed the coolant level is low? Checked oil, no coolant contamination, no major leaks. is this typical??
That was my recollection. Two different loops.How is engine coolant loss related to your OASIS if that's what I'm looking at? Also, that is one messed up fitting when compared to the others.
Doesn't OASIS use the hydronic heating fluid vs engine coolant?
I traced my coolant leak to this spot as well. No idea why they put a fitting here instead of just running hose all the way or a clamped coupling. This was a SOB to get tight enough to not leak.
The oasis uses a 3 layer flat plate heat exchanger (HX). There are several sets of the 3 layers stacked (6 if I recall correctly) . The HX contains independent passsages for engine coolant, Oasis fluid, and domestic water. If driving in the winter and you turn on the oasis burner, the engine will furnish most/all the heat via the engine coolant running through the HX and heat transferring to the oasis fluid across the plates. If you install an optional pump, you can have engine preheat from the oasis via the same but reversed process.How is engine coolant loss related to your OASIS if that's what I'm looking at? Also, that is one messed up fitting when compared to the others.
Most likely a defective HX in your Oasis. I assume you could replace only the HX. Brazed plate HXs sometimes fail this way.I have an issue where potable water is leaking into the Oasis thermal fluid, causing the overflow tank to vent liquid. I first noticed this when dry camping and heard the water pump cycle about every 10 minutes. Checking for leaks, the only place I could find a leak was at the Oasis overflow tank.
