Lightship AE.1: TrekDrive real world towing data (electric truck edition)
Rory (Lightship Team)
Commercial Member
Denver, Colorado
Lightship
AE.1 Atmos
TrekDrive Propulsion
Ford F350
The lab is the lab and the real world is the true test... so.. how efficient is the Lightship AE.1 in real world conditions?
We believe that our proprietary TrekDrive propulsion system and vehicle aerodynamics pair to produce the best performing trailer on the market.
But - the numbers should speak, so Ben (cofounder, chief product officer) and I ran two real world loops over the past week... below is the raw data. This data, along with qualitative observations, will allow us to keep improving performance and feel so that customer Lightships get better all the time.
We ran these two loops with electric trucks - and will do the same with diesel, gas, and hybrid trucks over the months to come.
In the meantime, see the TFL review for diesel towing data, at the bottom of the post.
Maps below, full real world video recaps to come.
Sat Dec 6, 2025: Ford F150 XLT Lightning Flash - Extended Range (2024 Model) + 2026 Lightship AE.1 Atmos
Route: Ben towed the below loop up to wine country, leaving from our office in South San Francisco. 196 miles. Combination of city, winding mountain roads, highways.
Weather: 50s and 60s. Overcast. Mild crosswinds.
Speed: stop and go thru SF; speeds of 25-50 mph on the coastal / mountainous section; 50-60 mph on the river road section (connecting to 101); 60-65 mph on the freeway back to SF with some traffic coming over the bay bridge.
Goal: Demonstrate the performance of the AE.1 in rolling and mountainous terrain, and show the potential of the Lightship to unlock a camping destination (Russian River) that would otherwise be unreachable for EV trucks without charging stops.
Benchmark: Lightning (extended range) ~90 miles towing with large travel trailers.
Departure: Ben left around with the Lightning at 100% SOC and the Trailer at 96% SOC.
Result: We returned to the office with 29% SOC on both the Truck and the Trailer. Running the math, the Truck consumed 93 kWh over the course of the route and the trailer consumed 47 kWh. This means the Truck saw efficiency of 2.11 mi/kWh average over the course of the route (vs ~0.69 mi/kWh towing other trailers).
Tues Dec 9, 2025: Rivian R1T Dual Motor Max Pack (2025 Model) + 2026 Lightship AE.1 Atmos
Route: I towed the loop out into the planes east of Denver. 266 miles. Outbound losing `1000 ft of elevation and gaining it back while climbing back into Denver.
Weather: 40s and 50s. Overcast. Significant swirling winds, with gusts up to 40 mph.
Speed: Highway speeds of 70-80 mph; backroads of 60-70 mph, and in and around the city of 30-50. Average 57 mph.
Goal: Demonstrate the performance of the AE.1 in adverse conditions - cold and windy - and run both the truck and the trailer to completely empty for a true range test.
Benchmark: Rivian R1T dual motor max pack ~140 miles towing with large travel trailers. In these kind of conditions and at 70+ mph driving speeds, perhaps closer to 100 miles of range.
Departure: We left at 9am with the truck at 100% and the trailer at 98%.
Result: We completed the loop without charging stop. It was super close returning to the factory and arrived with the truck at 3% and the trailer at 0%... we continued looping the factory lot until we hit zero on the Rivian at 270 miles all told, amounting to an efficiency of 2.03 mi/kWh (vs ~1.00 mi/kWh towing other trailers). This was a good result in these conditions, and support previous range testing we have done in warm and flat conditions where we have gone beyond 300 miles of range. On shorter routes with TrekDrive active the whole time, we would expect efficiencies approaching and even eclipsing 3 mi/kWh.
TFL review:
Rory, thanks for some real world results. The learning curve, for even some experienced RV owners is steep, as we begin to explore the world performance of electric RV's and tow vehicles.
There is one more variable that has to be considered when comparing performance: density altitude. In your comparison above the Rivian had a 14% advantage in efficiency over the Lightning because it was operating at 5,000' MSL, while Ben was pushing the air at sea level.
Somehow we need to find a way to standardize these measurements accounting for all the variables at play when comparing different tow vehicles. When towing, speed and density altitude at highway speeds are the major players and constantly changing.
drag force F_d = ½ × ρ × v² × C_d × A
Where ρ = air density and v² = speed.
View attachment 30727View attachment 30728
TFL review:
Rory, my question is, if the real world test is to reach a camping destination -300 miles away with as you say “no charging stops”, which you could only do with TrekDrive, (which is the point for the demonstration), what do you do when you get there and TrekDrive has drained the towed vehicle’s ( Lightship’s) battery while the towing vehicles battery is likewise at or near zero soc? Isn’t it the case that the Lightship’s solar panels would require nearly a week to restore the 77kWh battery, provided nothing in the RV is pulling off the battery in the interim? Not to mention how would you charge the towing vehicle?
[/QUOTE]
Great points!
Lots of variables at play, a quick summary for electric trucks:
Altitude (drag) - better
Altitude (drivetrain efficiency) - minimal change
Cold - worse
Wind - worse (provided no prevailing tailwind)
Speed - worse above 25 mph
[/QUOTE]
Also a great question. Really how you use trekdrive and the trailer battery depends on the situation.
One relevant example. You travel to a destination 180 miles away. You tow for 3 hours with trekdrive. You drop the trailer at the site with 120 miles left on both trailer and truck, or roughly 40%. On the Lightship that is still around 30 kWh, enough to last you several days even if not plugged in to shore power (conditions dependent). Meanwhile, 40% on a Rivian Max unladen is close to 200 miles. So you have 200 miles to go adventure around the area! Yes, you will need to stop at a fast charger with the truck before towing home, but that is potentially the only stop you need to make the whole trip. A Rivian fully charged towing an AE.1 should make it 180 miles home without trailer trekdrive, due to the aerodynamics of the trailer (lowered canopy). Depending on how much battery you used camping, you can also engage trekdrive to burn the remaining battery and make it easier!
There is one additional advantage towing with an EV that has vehicle to load plug capability. If your destination is at a site without electrical hook ups for the LightShip, you can unhitch and take the EV to the nearest charger then "tanker" back the EV charge to the LightShip and then charge the LightShip using the EV's vehicle to load feature via a portable NACS adapter.
This is one feature that gives an advantage to EV's towing a LightShip. With a pure ICE truck there is no easy way to bring a charge to the LightShip except with a gas generator.
The F-150 HEV Powerboost tow vehicle covers both bases with the ProPower on Board 7.2 kW generator since it can convert gasoline to electricity at the campsite then transfer the electricity to the LightShip using the PPoB generator vehicle to load plug in the bed.
One clarification on this statement. Only the Cybertruck and the Ford Lighting have a 240 volt charge plug. The Rivian pickup does not.
Detail from Grok:
The Rivian R1T does not have a 240-volt vehicle-to-load (V2L) outlet or plug.The R1T provides several built-in power outlets for powering devices from the vehicle's battery:
  • Multiple 120V AC outlets (two in the bed, one in the gear tunnel, and others inside), rated at up to 15A each and sharing a total limit of about 1,500W (1.5 kW).
  • These are standard 120V household plugs, not 240V.
Unlike competitors such as the Ford F-150 Lightning (with up to 9.6 kW Pro Power Onboard including 240V outlets) or Tesla Cybertruck (with 240V capability), the Rivian R1T lacks a native 240V outlet in the bed or elsewhere. Discussions in Rivian owner forums and Reddit threads from 2024–2025 confirm no 240V V2L adapter or built-in 240V plug exists, even on second-generation (Gen 2) models.Rivian supports bidirectional charging for future vehicle-to-home (V2H) use via third-party hardware (e.g., from Enphase or Wallbox), but this is not the same as a direct 240V plug on the vehicle. Sources include Rivian owner manuals, Wikipedia specs, and community reports from Rivianforums.com and Reddit/r/Rivian.
Yea, I very much intend to start with campsites that have power to run and charge up the camper for the return trip home.
But as you note @turbopilot I’ll be able to run my camper off my truck (Cybertruck) or even pull from the camper to charge up the truck.
A trip into town ( most have Superchargers these days) can top off my truck battery while I eat lunch.
There is a new post over on the Pebble Flow forum by someone on their first "test" camping trip without hookups and they have a Rivian. Dark December day and they could use some juice for the Pebble but the Rivian can't help except to run some 110 volt cords into the RV from the small Rivian inverter. I have no experience with the Rivian, so I just assumed it had 220 volt vehicle to load. Nope.
Interesting, wasn’t aware of that limitation on the Rivian. Yea, I can throw a little over 11kW off the 240v outlet
In the bed and pull from the 123kWh pack.
Tesla NACS mobile connector will only handle 7.7 kW through the NACS port to the LightShip. Good enough. Last April I had a chance to plug in to one of the prototype LightShips from the 7.2 kW inverter on my F-150 PowerBoost. Did not have much time to play with it but the best I could do was about 6 kW into the Lightship. But it worked. Going to take a while to put a dent in the LightShip 77 kW battery. The PowerBoost V6 was running pretty much all the time at 1,000 RPM to keep up with the draw.
Yea, I’m guessing I can also just run the essentials on the camper and not recharge the battery if my truck charge was low.
But realistically, if I was off grid for my destination, I would stop at a charger on the way there and top off both my truck and the camper batteries at the same time
If you’re not towing with an EV, you can still get a Tesla account and use their chargers to charge the camper as well
Great discussion. Personally super excited about the ability to “tanker” energy around. When boondocking, you could drop your trailer and set up camp, charge up the trailer from your cybertruck overnight, then stop at a supercharger next day to recharge your truck.
Tesla’s PowerShare should do up to 9.6 kW charging the trailer from the 240V. Enough to fill the trailer battery overnight.
Good clarification! PowerShare to home vs Mobile Connector have different limits!
Here is a summary of the EV trucks that can supply 240 volt vehicle to load.
The only hybrid truck that can supply vehicle to load (through local gas conversion) is the F-150 PowerBoost with 7.2 kW ProPower on Board option.
EV Pickup Trucks with 240V Vehicle-to-Load (V2L) CapabilityAs of December 2025, several electric pickup trucks offer 240V V2L functionality, allowing them to supply power to external loads like appliances, tools, or even homes (via compatible setups for V2H). This typically involves a 240V outlet in the truck bed or frunk, enabling higher-power output compared to standard 120V outlets. Below is a summary of currently available models, including their maximum V2L output and key notes. Note that full V2H (vehicle-to-home) often requires additional equipment like a bidirectional charger.
ModelMax V2L Output240V Outlet LocationKey Notes
Ford F-150 Lightning (2025)9.6 kWBed (one outlet) + four 120V outletsIncludes Pro Power Onboard; can power a home for up to 3 days on extended-range battery. Supports V2H with Ford Charge Station Pro.
Chevrolet Silverado EV (2025)7.2 kWBed (one 240V port) + up to five 120V outletsPart of GM's Ultium platform; enables V2H with GM Energy PowerShift Charger kit.
GMC Sierra EV (2025)10.2 kWBed (one 240V outlet) + multiple 120V outletsPower Station Pro system; supports air compressors and heavy tools. V2H compatible via GM kit.
GMC Hummer EV Pickup (2025)19.2 kWBed and cabin outletsHighest output here; ideal for off-grid or worksite use. V2H/V2V supported with additional gear.
Tesla Cybertruck (2025)11.5 kWBed outletsSupports V2L, V2H, and V2V; can charge another EV or power a home during outages.
Additional Considerations
  • Rivian R1T (2025): Offers 120V V2L (1.5 kW total) but no 240V yet. Full bidirectional (including 240V) is targeted for late 2025 or 2026 via software/hardware updates.
  • Upcoming Models: The Ram 1500 REV (with 240V V2L up to ~7.2 kW) is projected for 2026 availability. Scout Terra (2027) and Ford's midsize EV truck (2027) will include 240V V2L.
  • These features draw from the truck's battery, so monitor remaining charge to avoid stranding. Always check manufacturer specs for exact compatibility with your loads
