AI Quick Comparison of Electric RV's
turbopilot
Prescott, AZ
LightShip
AE.1 Cosmos
Electric
Comparison of Electric RV Specifications
The LightShip AE.1, Pebble Flow, and Evotrex PG5 are all advanced electric travel trailers designed for efficient towing, off-grid capability, and modern amenities. They feature battery-powered systems, solar integration, and propulsion assists to reduce tow vehicle strain. Below is a side-by-side comparison of key specifications in a table format for clarity.
Specification
LightShip AE.1 Atmos
Pebble Flow
Evotrex PG5 Atlas
Exterior Length
26' 7"
24' 8"
28' 8"
Exterior Width
8' 5"
7' 7"
8'
Exterior Height
6' 11" (Road Mode) / 10' 1" (Camp Mode)
8' 9"
9' 5"
Interior Dimensions (L x W x H)
22' 7" x 7' 4" x 7' 5"
21' x 7' x 6' 5"
22' 11" x 7' 2" x 6' 6.74"
Dry Weight
7,200 lbs
5,800 lbs
8,900 lbs
GVWR
8,200 lbs
6,800 lbs
9,900 lbs
Tongue Weight
792 lbs
680 lbs
Not specified
Water Tanks (Fresh/Grey/Black)
50 / 35 / 30 gal
40 / 37 / 18 gal
60 / 30 / 30 gal
Battery Capacity
77 kWh (LFP)
45 kWh (LFP)
43 kWh (LFP)
Solar Capacity
1.8 kW
1.1 kW
1.5 kW
HVAC System
20,000 BTU High Voltage Heat Pump with Drive Train Heat Scavenging
15,000 BTU Heat Pump HVAC
17,000 BTU HVAC
Self Propelled System
TrekDrive™ self-propulsion 20 kW(Peak 70 kW)
Magic Pack Self Propulsion
Active Power Assist Self-Propulsion
Off-Grid Capability
7+ Days
Up to 7 days
7+ days
Sleeping Capacity
Up to 4 (optional Summit sleeper for more)
Up to 4
4 (two queen beds)
Key Features
Auto-leveling, panoramic windows, dishwasher, induction cooktop, LookOut cameras, home backup power, Starlink Integration
Magic Hitch auto-hitching, InstaCamp one-touch setup, Starlink integration, quiet HVAC, tankless water heater
Terrece™ rear patio, dynamic skylight, projector screen, zero-wood construction, remote parking, tank heaters, Horizon Generator
Price (Starting)
$184,000
$139,500
$159,990
There seems to be no particular standard for what 'Starlink Integration' means. On the Pebble it means there is a hole in the floor that you can run a cable through to a Starlink external receiver. I don't consider that much 'integration'. What does it mean on the LightShip or other RVs? Seems like 'Integration' would suggest the RV is equipped with a Starlink dish and a Wi-Fi router and the necessary cables. If it just means it has 120V power you can plug whatever you want into, then the term is meaningless IMHO.
I'll tell you what I know about LightShip Starlink integration and Rory can expand. I was told LightShip has a built in cellular router. The cellular connection if for LightShip support, not customer communication but it does have WiFi that can be used. There is also a built in WAN port on the device that is wired to the AeroHub ethernet port. That is where a Starlink connection would be plugged in. The Atlas tablet system communicates over WiFi to that same cellar router WiFi connection then interfaces with the LightShip CANBUS body controllers.
@Rory (Lightship Team) this was information I got from Ben last April. Let us know if it has changed or if I got anything wrong.
That's spot on, @turbopilot ... the customer won't see/interact with the system as you just described it, but were a customer to setup a starlink device, our vehicle systems could switch over to that starlink system, which may be beneficial for over the air updates etc in terms of speed.
More directly obvious for the customer is this:
- Some starlink setups (like starlink standard model) come with a separate modem/router that need to be kept out of the elements and still wired to an external starlink dish. To make this easy, the Lightship comes with a build in tray under the dinette bench where the customer can a) store the modem/router b) plug in the modem/router to 120V power and c) connect the modem/router to a pre-wired ethernet cable. The ethernet cable accessible in that location then wraps through the internals of the vehicle and connects to the port on the tongue box that turbopilot describes. from there you can plug in the external dish with an ethernet cable to connect the whole system, and position the dish externally to maximize signal.
- other starlink setups (like the starlink mini), come with the modem/router integrated into the dish. in this case, all that is needed is to position the dish externally and plug it in to the 120V outlet on the tongue box for power.
@PhatDaddy does that answer your question? true "integration" is hard to achieve since customers bring their own hardware and starlink subscriptions, and may not be optimal since positioning the dish externally is a benefit for signal.
Here is that area on @turbopilot ´s VIN. Tray, Ethernet, 120V. Plastic on cushions to keep them fresh ahead of delivery! We'll do a thorough clean and detail (exterior/interior) before delivery so please ignore the dust.
Thanks Rory. Yeah that covers it, and I would agree that the LightShip setup you describe could fairly be considered ‘Starlink Integration’. It provides a method for external access and supportive wiring, power and space for the owner to add the necessary Starlink components. Good show!
Nice to see 120V in that area for other hidden equipment.
totally, great area to tuck things away. Some aftermarket wall mounts could secure items in place for transit, it’s a large area.
@PhatDaddy I see you're in Central Florida, are you planning on going to the Tampa RV show? We'll be in the camping area and giving TrekDrive demos off site, stop by if so?
