How to Level Vienna on Site that Exceeds Leveling System Capabilities
MDC2570
Hi, I’m new to forum. Purchased a 2026 Renegade Vienna RML with delivery this spring. My past MH didn’t have a leveler/stabilizer system, which comes standard on the Vienna. I expect operation to be simple, but I’m unfamiliar with the leveling process for more extreme uneven camping sites which we use often. Can anyone share the accepted process to level the MH when tilt exceeds what the leveler system can handle? For example, should I add leveling pads at tires first before enabling the leveling systems. Or should I level with pads only at the leveling jacks? Maybe a combination of both? Also, does anyone know the mfg and model# of the 2026 Vienna leveling system so I can research the limitations? Finally, any suggestions for best leveling pads for the Vienna? Many thanks in advance!
Driving up on blocks isn't something you'd ordinarily do on extreme grades where you intend to use the leveling system. If the grade is so extreme it's beyond the capability of the jacks and you block up under the jacks you're likely going to end up with wheels off the ground and a bad outcome.
Your owners manual should have operators instructions for the "Equalizer Systems" on your MH.
Thanks Holdmybeer, I appreciate your quick response! I understand your point and have also read that leveling systems are normally not designed to lift wheels off the ground, so I wouldn’t do that. But I’ve also read recommendations to first level reasonable at wheels with leveling pads, then at jacks with leveling pads. But I’ve also seen RVs with several leveling pads only under the jacks. I’m not planning to do this in an extreme uneven site, but more at a moderate uneven site that, let’s say, exceeds the level system by several inches (assuming that isn’t considered extreme😊). I wouldn’t risk sliding off the pads.
I suppose another option could be to just drive up on stacked leveling pads, as I did with my prior Greyhawk, and not engage the leveling system.
We don’t like our tires off the ground, so we use blocks under the wheels to get close, then use very wide blocks/boards under the jacks so they don’t have to extend far.
Thanks MemoriesByTheMike, the consensus seems no tires off the ground so I’ll be sure to not do that. Sounds like you’re saying level at wheels first with leveler pads/blocks, then extend levelers onto level pads/blocks. That seems like a good method with a focus of not doing anything extreme as pointed out by Holdmybeer.
Any other recommendations/opinions from the forum? Thanks!
Okay, wheel off of the ground is NOT recommended. We have been in situations where there was no way to get level without a wheel (or both) off of the ground. Let me confirm!!!!! NO REAR WHEEL SHOULD EVER,UNDER ANY CIRCUMSTACE, BE OFF OF THE GROUND. The park brake locks the rears and your coach needs to be solid. Now, back to FRONT wheel off of the ground. What we have done was to level the coach. How much off of the ground is measured. We then lifted it about an inch or so higher then set the appropriate height of blocks under the wheel (s). Then lowered the coach so the tires rested on the blocks. We do this for two reasons. With tires flat on a surface, our coach doesn't rock when you enter or leave nor does the wind bother it much. Second, should the jacks fail, it would be difficult to retract our slides. The Jayco bible says coach must be level to use slides or there will be difficulties extending and retracting. We have never had to use more than 5 inches of blocks. I'm not sure I would be comfortable using more. With blocks, in my opinion, your coach should be a solid as if it were on the ground.
Great advice Rollin, and forum! Got it, rear wheels NEVER off the ground to ensure e-brake is functioning! For front; level, measure, blocks, and lower, to prohibit rock & blow, and support slider operation. Around 5” of tilt max, and ensure resulting setup is secure, and read manual. Unless anyone has anything to add, I believe I’m all set, and hopefully this will be useful information for others. If I learn anything additional during my upcoming leveling experiences, I’ll be sure to share it. Thanks again forum!
