Transfer switch gone
DennisT
Superstar 4061
FCCC
Cummins 360
2022 Jeep Cherokee TrailHawk
Well, three years of full timing yielded a bad ATS.
Happened the day after Thanksgiving at 4 in the morning. Luckily our friends, in the site next to us that also have a Superstar, had the keys while we were gone.
The shore breaker started chattering so loudly that it woke him up.
Got in touch with the park repair guy we trust and he bypassed it till we got back Saturday morning.
North Trail had one in stock so, after driving for 22 hours and a short nap, drove another 3 hours to pick it up. Had the RV guy install since I was a little tired.
Reached out to the manufacturer and they do not rebuild them so $1200 paperweight as a spare. Generator side breaker is still good though.
Bottom line - when away, if possible, have a friend or neighbor with keys to handle issues if they arise. Glad our friends were available and heard the noise.
Sorry to hear this but I suspect something caused this and it sounds like a bad pedestal. Can you explain what protection you use between your ATS and the pedestal?
I'm a bit over protected but nothing wrong with that I suppose. I use a Progressive SSP-50XL plugged into the pedestal which gives me a visual with lights if the pedestal is wired correctly and is first line of defense.
Then the cord reel feeds into my Hughes Autoformer.
My Hughes Autoformer flows into a Progressive EMS-50.
The Progressive EMS-50 then wires into the ATS.
Nothing is going to take out my ATS unless it's an ATS failure itself. I also want to prevent my cord reel from getting taken out as has happened to some in electrical storms hence the pedestal first level defense.
Campground grids are crap and we are taking very expensive fragile electrical rigs into high risk power sources. Protect your rig!
Mine overheated and melted the terminals while at a campground in S. Texas. I bypassed it and carried on with the trip, only the generator wasn't an option until the switch was replaced or I reconfigured the bypass. I assume there must have been a loose connection in the switch itself. The Progressive EMS at the pedestal never blinked.
I have a Watchdog EMS Wi-Fi model on the pedestal before anything goes into the coach. Our ATS also has an EMS board.
No errors on the watchdog. Bad ATS shore power side breaker. Believe the solenoid that holds the breaker closed went out causing the chattering.
Interesting note that at least 2 other Newmars in the park, 22 model year, have also had theirs fail.
Would be nice if Newmar used one that we could rebuild if needed.
Bummer! Thanks for the follow up info. Love RVing when all works, not so sure when we get challenges :(
You can rebuild those. I have the spare parts to replace it.
The bad news is it requires removing both of the contractors.
I purchased the parts from US Breaker in Greensboro GA.
Here is the parts list and pricing.
Is this a southwire ATS? I have a 19 Dutchstar, so I am kinda in between Neal and Baron. If it is the same as Baron's I am all in on ordering the parts and having them on the shelf
Yeah, Southwire.
They have a factory about 1/2 hour from where we are in FL which is why I hoped the would rebuild.
Ordering parts and rebuilding is definitely more cost effective since we have the one with the EMS in the transfer switch as well.
Is this model 40450? If so it would be the same as mine.
The 40350 also uses the same.
Here is a video on the install procedure
Here is an image I found showing the oem vs the us breaker side by side
Mine is the 40350RVC. I am ordering
Done. Prices have went up, $169 dollars now
total cost. Two breakers and the mechanical interlock. For that price, no charge for shipping
That’s not terrible.
From what I have seen, you will need to drill out the rivets to do the repair but otherwise very simple.
