And after three pages of posts in this thread that was exactly the thought I included in the original post in this thread.
I left the issue of weight distribution as an open question in the OP, subject to a lot more experience towing the LightShip, which hopefully will happen soon. But as others have clearly discerned I am skeptical about the need for weight distribution,
for my use case.
Let me be clear my first experience towing the LightShip prototype was with my tow vehicle (an F-150 Platinum PowerBoost). All of my opinions are centered around a LightShip being towed with my tow vehicle. I am not rendering any opinions about the LightShip being towed by other tow vehicles.
I have been towing a 2022 Airstream Globetrotter (25') with an F-150 PowerBoost since 2021. I probably have in excess of 30,000 miles experience, to date, with this combination. The PowerBoost GVWR is 7,300 lbs. The Airstream GVWR is 7,300 lbs with a hitch weight of 836 lbs. Typical use case is that both the PowerBoost and the Airstream are operated nominally at the full GVWR. For this situation combination I use a 114 lb B&W Continuum WDH that incorporates both WDW and excellent sway control in the same device.
But here is the surprise. That 114 lb B&W Continuum hitch when set up to Ford's 50% FALR specification returns only 181 lbs to the front axle. So you are putting 114 lbs on the rear of the F-150 in order to move 181 lbs off the rear axles to the front axles.
For a 7,300 lb pickup is that additional 181 lbs really worth all the extra cost, weight and inconvenience of using a WDH? That is a question not a conclusion.
Now consider the LightShip being towed by the same PowerBoost. The LightShip weighs 1,000 lbs more fully loaded but it has nearly the same hitch weight. So from the tow vehicle's standpoint the same numbers apply, you add 114 lbs of WDH hardware to the rear of the PowerBoost in order to shift 181 lbs from the rear axle to the front axle.
Manufacturers set the FALR for their vehicles to optimize the understeer associated with towing a trailer and that adds weight on the hitch. Ford sets the FALR at 50% for their pickups. So the question to be answered is how much difference is adding 181 lbs to the front axle is going to make when towing a CGWVR of 14,600 lbs in the case of the Airstream or 15,600 lbs in the case of a LightShip.
I do not have the answer. I am posing a question. But for this particular combination of a towable and a tow vehicle, I am skeptical that the pain is worth the gain.
The B&W Continuum WDH has some strong anti sway qualities that is helpful with the Airstream, so I think the that WDH made sense towing the Airstream for the anti sway attributes. But the LightShip is going to be much more resistant to sway and it is being towed by a PowerBoost with a built in trailer anti-sway system.
So for my use case, where a sway control device may not be important, does it make sense to put a heavy device on the rear of the truck to return 181 lbs to the front axle?
And now here is the data to support my off the wall speculation. This spreadsheet represents the actual four corner weights associated with my F-150 PowerBoost set up to tow the 25' Airstream using a WDH set to 50% FALR. From the standpoint of weight distribution on the hitch the numbers will be the same for a LightShip.
