Your answer helped me also, but, I don't know how I would connect my Blackstone without the provided regulator connection. If you have any advice, or links to a connector purchase idea, I am game for anything. Advice is always welcome.Are the appliances designed to hook up to a screw on one pound bottle? If so, you probably have a regulator on them. The quick connect has regulated pressure (approx. 11 inches of water column) and if there is another regulator down stream on the appliance the pressure will be so low you won't be able to keep them lit. You would need to remove the regulator on the appliance to have it function properly.
On the Blackstone the regulator is on the short line that the 1lb bottle uses. Go on line and look for a Blackstone grill extension hose. It will connect directly to the grill connection then add the correct fitting you need to the other end to connect to your RV
Got it, it works. Thanks
