Question Electric issue
Buckeye97
Hello everyone. I have a weird electrical issue. I have a 2018 jayco jayflight 17 footer what all of the sudden has no power from one breaker. I checked all breakers to the neutral bar and I have 120v to all breakers. I have no power at all to my first gfci and no power to my fridge or to a couple of other receptacles (diagram says the same 15A breaker controls gfci and fridge). I do have power to one receptacle by breaker box and to microwave. …also to ac unit (red light is on). I have no power to that gfci so replacing it is moot. Breaker seems good. Ugh. Any ideas?
Also, this happened all at once. It all was ok then all of the sudden space heater stopped and I woke up ice cold.
If the circuit which the refer is on has an outside outlet anywhere in it then it’s likely to have a master gfi involved somewhere upstream. If the upstream gfi is tripped your 15 amp breaker won’t know it. Check any gfi with a reset button ( start with the bathroom) . Gfi’s btw don’t ordinarily play well with space heaters.
