Underboss
- Nov 17, 2023
- Titusville
- 2020 Blazer
If you are going to own an rv, avoid Palm Coast at all costs. I know I owned a lot and was going to build there. The general heart of PC has no HOAs but the city itself is a huge HOA. Insane rules that are not applied unilaterally. RVs are not welcome, even class b van based cannot be seen from the street or neighbors so they must be garaged. The city loves to send out letters if you have your rv in your driveway for a week. No rv garages allowed, in fact garages are not allowed to be more then 30' deep and the roofline cannot be higher than the rest of the house. There is actually one home in all of PC with an RV garage and after that house they made a building ordinance against it.
As for traffic and overcrowding, drive through PC midday and its as bad as NYC in commercial areas.
Some of the 'hoods have no lights at the main street so either you have to go right and make a u turn somewhere or take some convoluted route to get to an intersection with a light.
As I posted before, the northeast area has higher utilities. My friend pays $240/mo for water and sewer on a 1/4 acre lot with less than 600 sf of lawn. You can put a well in but unless you filter it the water is brown and stains everything.
If you buy a home anywhere in FL do not let the realtor pick the inspector. research and pick one yourself. The builders mesmerize folks with amenities, layout but the windows doors and finishes are not real quality.
You also want to avoid stucco covered wood frame homes here. The humidity and moisture are not a good mix with stucco covered wood frame homes.
You should look for poured in place concrete construction as the best. Concrete block is good also.
May have been a long read but as a builder I research everything. My only error was buying and planning to build in PC as a friend who was on the PC planning commission told me I could do an rv garage and as he was also a builder, I thought he knew and trusted his knowledge. Clearly he was clueless, buts thats Florida folks for you
