2026 Phantom Sport 23PS Dome Light
RickV
I have a new 2026 Phantom Sport with a Dual 7 inch radio. I have been trying to turn off the cab dome light, but it won't turn off. I have pushed on it and it refuses to turn off. When I picked it up, the guy said to turn off the dome light you have to do it through the radio. Does anyone know how to do it?
If this were true I would be looking for a menu on the radio for such settings. Perhaps consult the radio documentation.
On your main touchscreen tap Home or Apps launcher, then Vehicle Settings, then the vehicle tab, then Lighting Menu, scroll down to Lighting.
Then thank Nexus for figuring out a way to simplify turning a light off. Switches were physically demanding and confusing.
Thank you for responding. When I go to settings, there is no vehicle tab. The only light settings I can find are for the screen.
Try looking for "Doors & Locks" or "Comfort & Convenience" then select lights from within that sub menu. There could be a pulldown menu, if so swipe down from the very top of the screen. Look for a light bulb icon, tapping this,will immediately kill all interior "polite" lighting.
Look at the button, directly on the light or on the console above the rearview mirror. There.is usually a button marked "Door" or "Off". If the physical button is clicked to the on position the radio software will be locked out and won't show the toggle switch because the physical switch is forcing the circuit open..
Otherwise, surely there's a binder on board there somewhere with operating intructions for the infotainment center.
Thank you, I will try and play with it some more hope to figure it out.
