Wish I could find that parasiteIf they re hooked up, there are always parasitic draws… the only way to truly help prevent this is to disconnect them. Or leave them on charge.
At 11.5V, the batteries are already essentially dead. Is this just sitting with no known loads, or is it being used?Need help understanding what is drawing power from the house batteries. Fully charged after a long winter, first day 11.5v 24 hours later then batteries are dead. These batteries were replaced last year, no appliance running. What could be draining these batteries.
You mention in the title a Magnum Inverter. Why? Are you actually using it and running the batteries down? How long were the batteries dead? Lead acid will not recover if left dead for long periods of time. I sorta assumed the batteries died when not being used after the winter....but were you boondocking?
So much to learn, should I be turning off the inverter I left it on to display the battery v. Set to auto start up for the generator will that work if the inverter is off? I am thinking the generator didn't start as the batteries were depleted. I wish there was a better on line tutorial for new users. I found a couple that has the basic, no place for Q & AAt 11.5V, the batteries are already essentially dead. Is this just sitting with no known loads, or is it being used?
Use the search function for your personal Q&A. Auto start indicates newer rig. Tell is what rig and monitoring system installed in your rig.So much to learn, should I be turning off the inverter I left it on to display the battery v. Set to auto start up for the generator will that work if the inverter is off? I am thinking the generator didn't start as the batteries were depleted. I wish there was a better on line tutorial for new users. I found a couple that has the basic, no place for Q & A
Should be unplugged as there is no reason to use the inverter when plugged in. But we know that's a mistype.plugged in
