Question Wind noise
How do you get rid of wind noise on a 2024 Entrega Quest 24L entry door?
Was weatherstrip installed correctly from the factory? Does the door open and close easily? I believe the only adjustment available is at the striker (maybe a little on the latch). Can you move the striker in some?
Depends on any number of factors. First, at night turn off all interior lights, cover the window in the door and turn the porch light on, look for light. Hopefully they didn't throw a LH door on the passenger side, standing outside the hinge should be on the right. If it's just rattling in the hole try what Rollin advised.
Mine rattles on bumpy roads unless i lock the deadbolt. But no wind noise
DW uses ear plugs, what? can't hear you..it gets old, lol
Make sure the door is shut all the way, they have 2 settings, one for when in use and one for when driving. If the door isn't properly adjusted it may be staying in "use mode". Travel mode the door should be flush with the body, use mode it'll be out a good half inch. They are easy to adjust.
