This is disgusting.....but I think common
TR25
Vagrant
Many
Many
Last RV I bought, this was the fresh water tank. When I commented on the color, the previous owner's response was "we don't drink that."
Still disgusting--to me anyway. You wash your dishes in that. Shower with that. Brush your teeth with that. You're spreading fungus/mold through your water pump, lines and water heater. Heck, just having a biological warfare lab inside my RV is enough to gross me out.
Do you/is this common? Since then I've asked people and a lot don't drink from their 'fresh water tank', so I guess never checked it.
Someone could make a lot of money if they 'invented' a bottom, as in the underside of the tank, drain on fresh water tanks.
The problem is they are unicorns as much as I can tell, so there will always be 3/4 of an inch in the bottom of the tank...and that's a recipe for a fungus factory.
Half considering cutting a hole and putting in a hatch on top so at the end of the season or as part of routine maintenance, I can sponge out all of the water there, leaving no standing water.
Do you check yours?
We never use ours for drinking water. I usually sanitize it once or twice a year, depending on usage. Actually, we stay at campgrounds 99% of the time, so I usually just run off the campground's water (through two filters and water softener) and keep the tank at about 30-50% for use when on the road for toilets and such. We always use bottled water for drinking.
We drink from ours all the time. I santize the complete system quarterly.
BTW, thanks for the reminder. I'm doing it now.
We are full time.
Sanitize yearly, tank water is replaced monthly to keep it fresh. We use what is in the tank before the month is up rather than just drain.
Use it for everything - drinking, ice maker in fridge, etc.
No issues with the water.
We also have a three filter setup outside along with a water softener and the whole house filter.
The same process for us.
We use our tank water as we mostly dry camp/boondock. We have a two stage system with 0.05 micron and 0.02 micron filters. Both are changed every 6 months when we sanitize. Someday, I need to install a better tank drain.
My rig has no holding tanks! I use a pickle barrel sitting outside the rig as a kind of cistern for My plumbing system.
That explains My answer to your concerns.
On the boat, the tanks had irregular bottoms,and I hatch on the top. I could use a pressure hose to spray the dirt out when a hose was available. But I never had that luxury available while cruising. Irregular bottoms made using a wet vacuum the answer whenever I put it on the hard.
You could put a standing pipe on one end of your tank that has a sarated end so you could park unlevel, and vacuum the last remaining water out before storing. Caution! Inlet pipe should be open if you do such a thing.
Always use potable water, and always keep All ports closed. That will keep the organisms out of the tanks. That will not stop sediment in the bottom of the tank.
We almost always stay in RV Parks or State Parks with city water. Our "fresh water" usage is limited to a few gallons while we are en route for flushing the toilet or any other incidental usage, but not for drinking. I'm not sure we have ever used the water pump and fresh water for kitchen sink use.
Do you check yours?
Well mine does not look like that.
One thing that surprised me was the arsenic in groundwater. I was under the impression it was due to farmers being bad people, but nope. If the water gets filtration through limestone, one of the side effects is arsenic.
as with any bodily reaction to something, some people can become sensitized to it if exposed to it long enough
Yes natural,or introduced over time. However it is poison. And like all poison, when the volume in the body reaches toxic, the body shuts down.
The question is what is your threshold?
Tolerance. That's always the million dollar question.
With osha for example, I posed a question regarding 'dangerous' substances. They drill into people, "dilution is not the solution".
OK, then going by that, why do you measure permissible levels in percentages, concentrations of the item to the whole?
Yeah, those mandatory meetings were usually boring, even with the presenter sometimes.
"city water" can also have arsenic. A relatives house, the scale of 1-9 is OK. Anything above 9 is too much, a danger. The last water test they had done, it was a 9. So it's OK then. Or it's OK then? What's the dif between a 9 and a 10?
To your question, someone can have an allergy to dog dander for example. As long as they vacuum and dust their home/rv regularly, they are ok. Others will break out in reaction to most any pet dander, sniffling, if they pet a pet and rub their eyes, they get inflamed, etc.
The million dollar questions....
