Dometic A/C issue
Michael H
Hi Gentlemen,
I have 2021 Riverstone FKRB with 3 units. The rear two units appear to work ok even though fans are incredibly wimpy. The front unit blows warm inside. However, on the roof, the unit blows cold.
The other two units send cold air through the ducts into the bedroom and front bath, but not enough to even begin to cool the area.
I gave had an HVAC guy up there but he doesn't understand it either.
Does this make sense to anyone?
Thank you so much,
Mike
If you mean inside at the control panel, their is only on or off. No fan control.
Is their supposed to be a auto setting on the roof? I can tell you when the temp calls for the unit to run, the compressor kicks on and blows. It is just cold at the unit and warm air at the inside.
Thank you for responding
Do you have the front one set on HP (heat pump). This would work the opposite of the “cool” setting. That is warm on the inside and cold on the outside.
I would have to put eyes on it to verify that it is not a heat pump.....Then run a delta test to verify it is actually cooling air and blowing it out on the outside. IF there is no reversing valve in place I have never heard of one working backwards.
Can't work backwards.
