Generator LP Fuel Consumption
Dan_Frisbie
Wausau, Florida
Brinkley
G3520
40’ 3”
I have a 2026 G3520 with the flex-fuel generator. We never boondock and I do not plan to put gasoline in the generator tank unless I have to.
Since we live in Florida, the generator will likely only see use in case of power failure after a big storm.
What is the average LP consumption rate when used as generator fuel?
Your question is ridiculous as posed; how long is a piece of string? Kevin's response is far more informative than any answer to your question without additional information or parameters.
Actually it does. A simple Google search will tell you that at peak output you will burn about 1 gallon of gasoline an hour depending on the watt rating of your generator. Btu's directly convert to horsepower or watts etc.
No it’s not ridiculous at all.
I specified the RV, an owner of a similar RV would possibly have experience with the unit.
On average, a gasoline RV generator consumes .5 to .75 gallon of gasoline per hour. This is not specific to any particular RV or generator, it’s common knowledge in the RV community with 4000-5000 watt generators.
I know that I could spend some time figuring how to convert a gallon of gas to propane, but I would probably get the formula, weight, specific gravity, or something else wrong.
Therefore, I asked if anyone with a propane powered generator might have an idea of how fuel it consumes.
Or just ask google -
An RV propane generator typically consumes between 0.5 and 1.0 gallons of propane per hour, depending on the size of the generator and the electrical load placed on it (like running an air conditioner). [1, 2, 3]
Here is how usage generally breaks down:
  • Light load (just charging batteries, lights, TV): ~0.3 to 0.4 gallons per hour.
  • Half load (running one RV air conditioner): ~0.5 gallons per hour.
  • Full load (multiple heavy appliances running simultaneously): ~0.8 to 1.0+ gallons per hour. [1, 2, 3, 4, 5]
It seems you had all the data to extrapolate your answer but wanted to be spoon feed the answer and reject any comments that does not do this; it's your MO I've noticed.
No, just looking for someone with experience, not a bored old man that thinks his opinion on everything is some importance.
Or if you don’t know, then don’t offer.
Answer such as these are why so many people hate to ask questions.
If you don’t have experience, then don’t waste your time.
And that is not an answer. Depending on load ( what you will be powering), a personal habit thing. Your fuel consumption will be different from everyone elses. My answer was as specific as anyone will get.
our champion duel fuel 10,000 watt gen at 50% load consumes around 3/4 + gal gas per hr. on propane almost 1 gal per hr. also on propane you lose about 10% to 20% less watt power down to (8500/9000), in our unit . the PLUSside of propane is long engine life since it runs much cleaner. also try to always use non-ethanol gas as necessary.
This is all I wanted.
Common Sensed, Experienced Member from Another Forum;
I have a 4,000w portable genset. It will consume a 20# cylinder in 20- 24 hrs. depending on load.
Like you, I never plan to add gasoline to the tank, but will if required.
Thank you.
Exactly what I was looking for. Knowledge.
