Motorhome storage
soccer23
Holiday Rambler
Navigator
39’
Freight,iner
Cummings in-line 6 diesel pusher
2015 Jeep wrangler sport
We will be storing our MH off site for a few months while we have some home renovations completed. What is the appropriate way to store it in regards to the batteries? Is turning the coach batteries off sufficient enough to not ruin the batteries? Do they need to need to be removed and placed on trickle charger?
Thank you!
Thank you!
Get a battery maintainer, not the same thing as a trickle charger.
Just so I understand correctly, remove the batteries and use a battery maintenance device rather that a trickle charger?
Thank you for your response!
If you have power (not via a GFCI outlet) at your storage, leave the coach plugged in and set your inverter or energy manager to the appropriate amps to match your shore power. If you don't have power, simply turning off the "salesman" switch may not be adequate as on some coaches there are various parasitic loads that are connected upstream of the switch. I am just not familiar with your particular brand.
When we had ours in storage (with no shore power) for sometimes up to a month we used a 200 watt portable solar panel with a built in controller. We never had a problem. It was very easy to use. It came with Alligator clamps that tied directly to the hose batteries. We had a Go Power but there are many brands out there.
Thank you for your response! We have a roof top 175 watt solar panel. I just don’t know whether it is connected to the house batteries or the chassis batteries. House batteries appear to be liquid acid cell batteries and am concerned about boiling them out with all of the sun.
Thank you
Thank you
I'm very confident that your solar will have been connected to the house lead acid batteries. But I suspect Kevin D Penn will be able to help you a lot more than me. IMO he is the resident expert. Kevin......
No question it is connected to the house system.
I didn't know if you were going to shoot for covered storage.
Flooded as in golf cart batteries? Top them before storing. Turn off equalizer on your solar controller and you should not need to be concerned about boiling.
The solar won't keep the chassis batteries up. That is going to need addressing. Standard monthly maintenance should take care of that issue, and should be almost ritualistic.
And @Rollin Ollen you made My face flush! Thanks for the compliment.
To be certain that you don’t drain any batteries I would remove the main feed cables from the house and chassis battery banks
