Winnebago Intent
Notsoaverageguy
Sandiego
Winnebago
Intent
F53
V10
So not my first RV its my second A class but my last C class was long in tooth a 1996 C class E350. Everything worked great but it lacked the pizazze! And besides the wife wanted something newer. So it has all the bells and whistles we were looking for and just wanted to look here for tips as it is a 2018 with 8k on it am sure its going to need some love.
Welcome from Mississippi!
No I don’t think they even used the stove. But hoping to get someone with an Intent here to ask a question. The dash on this RV a A class, is made up from scratch. And the problem is it REALLY flexes up and down ( mostly noticeable in the center) when going over rough road. Very annoying. You can move just sitting still. Was wondering if anyone knows what I am talking about. It looks like I could make a brace on the bottom from what appears to be a metal plate to the engine cover. Anyone out there have any knowledge of this.?
I added two struts to the top of my motor cover on our 1989 HR Alumalite Class A.
Boat parts made it easy. Two bimini top pole end fittings each on the ends of two short tubes, landed in four of the attach fittings made for that, at top and bottom. Drilled out the attach point cross pin holes just a bit so that 1/4" diameter push button t-handle ball bins for quick release could be used.
(We had split the giant motor cover such that it was 70/30, hinged, front part hooked to the firewall with draw catches, struts to feep the front pushed down by the "under small tv" dash center.
Boat parts. The best RV fittings are mistakenly sold as boat parts....
Thanks for the reply I took a exercise noodle and cut it at 5" with an angle. It allowed me to slip it under the tight area and once there I could rotate it till it was tight. For now just an experiment.
Good idea! Did not realize that the space was small. Closed cell foam is nice and dense, might be all that you need - fingers crossed!
So just did a 150 mile round trip to the beach and really the worst roads are right when I leave the area. But it was a major improvement. Good enough for now while I tackle the overhead retractable bed. It to bounces and makes irritating noise. So I will keep up any progress unless anyone can tell me where to look.
The scissor linkage lowerable bed over our 1989 Hr Alumalite MH made squeaky, rattly noises while stowed and underway.
A few slim tapered wood shims that they sell in a pack for wood frame door installation work, shoved in the gaps between the scissor mechanism and the side mounting bases quieted it down just fine, were easy to extract at bed lowering.
You are doing great so far 👍
Yeah this doesnt have a scissor it has a track that it follows when it gets pushed out. I spent some time today pulling and trying to get the noise up there but to no avail, I am thinking the dash again but on the side . So will ook into it and see.
So I ran down the irritating noise on the right side of the dash. It resonated and sounded like it was coming from up high, but the wife said she thought it was coming from the left side of dash. So after thoughrouly checking the overhead bed situation I was easily able to dismiss that, So pulled of a lower panel on the right side and got down under and grabbed this and that and there it was. They mounted the air box/blower motor unit there, and while the box felt sturdy you could grab the motor and shake it up and down and the noise was duplicated!
Winner! Just put a hose clamp around the motor and made a bracket to go from there to the dash support strap. SO then I moved to the center of the dash where they hang the whole center front bezel that has the A/C management system along with the Auto Jack controls hanging off that and hold it on with 2 screws on top and 2 on the very bottom. SO that got 2 extra braces in the middle. Can wait for the next adventure.
Hurray! One by one your diligent efforts are bringing rewards! Before long you will have it much improved over how it was, totally worth the effort and very satisfying to gitter dun!
