Your Penguin II gets power to red and black wires on terminal P6 on the control board. It’s a 6-pin connector. I believe F16 fuse in half bath is power. This entire fuse panel is only powered when the salesman switch is ON connecting the house bank power to the panel, and other “disconnect battery powered” panels and breakers.
From the control panel, a 4 wire phone Jack looking connection goes to the CCC2 thermostat and provides it with power. In most installations, there are two of these jacks. They daisy chain. On our coach, Thermostat >>> Front A/C >>> Rear A/C >>> basement Dometic control box linked to ME-AGS-N (Auto Gen Start) .
If the saleman switch is ON, power is getting g to fuse panel and fuse is good, P6 terminal connections are good (check for 12v on the red and black), the phone wires are connected to the control board and the rear of the thermostat…you should be good.
