redbaron
Moderator
- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
I expect the new demand will give cause to raise the price on red dye also.Have seen some news releases recently regarding allowing use of red diesel for over the road equipment.
Curious if anyone is using it, your experience, and does the open roads fuel card work with a red diesel purchase?
Any thoughts on "long term" effect. Mostly wondering if the red dye in the system will somehow be an issue after the red dye use is once again off road only.
Red dye is the same diesel at the same price for fuel. The only difference is that it does not have part of the taxes. So, there is no differential supply-demand curve.I expect the new demand will give cause to raise the price on red dye also.
In the truck lanes at Love's, Petro, etc., isn't the "REEFER" fuel the same? Those truck stops are all along the Interstate highway system, so you don't have to search through a rural farm area to find red-dyed diesel. It is easily available commercially through truck stops.As pointed out above it’s readily available in rural farm areas, but you’re unlikely to find it commercially available elsewhere.
and when this scheme is over, you will have to change your red dyed fuel filters. So remember that cost will hit you down the road
So are distributors prohibited from raises their prices? Remember eggs a couple of years ago? Lower supply = higher price.Red dye is the same diesel at the same price for fuel. The only difference is that it does not have part of the taxes. So, there is no differential supply-demand curve.
Got pulled over once, years ago in a dp. I was clean so there was no issuesThe dye will wash out of the system after several cycles. I would guess there would be a grace period after the programs end. When in N. La. I would get pulled over and dipped occasionally, so the tinted exhaust, since I wasn't running farm diesel, wasn't necessarily all they were looking for.
What ever card you use has to fit the computers algorithm to allow you to pump Reefer fuel.............Like the Opens Roads RV fuel card will not allow you to pump it............In the truck lanes at Love's, Petro, etc., isn't the "REEFER" fuel the same? Those truck stops are all along the Interstate highway system, so you don't have to search through a rural farm area to find red-dyed diesel. It is easily available commercially through truck stops.
I believe that's all correct from what I've read.
Distributers can charge whatever they think the market will bear. Both regular diesel and dye diesel are exactly the same diesel. the dye diesel has dye added - that is the only difference in the product. Again - the pump price for regular diesel = diesel fuel cost + taxes. Pump price for dye diesel = same fuel cost + less tax. Obviously a distributer or retailer could try to gouge on the red dye, but the free market would soon bring him back to reality.So are distributors prohibited from raises their prices? Remember eggs a couple of years ago? Lower supply = higher price.
