Hello from Texas – Mechanic and Classic Car Restorer
Antonio GG
Hello everyone!
My name is Antonio, and I'm an experienced automotive mechanic and classic vehicle restorer based in Texas.
I've worked on cars, trucks, motorcycles, engines, transmissions, electrical systems, and mechanical diagnostics for many years.
I enjoy helping people understand mechanical problems and finding practical solutions without unnecessary expenses.
I'm especially interested in helping RV owners and travelers who experience mechanical issues while on the road.
I'm happy to join this community, share my experience, and learn from others.
Looking forward to meeting everyone!
Antonio
Texas, USA
Welcome. I am sure there are a few like me who are lost beyond changing oil and airing tires.😎
Antonio, the practical side of your introduction stands out. For those of us who can just about manage the basics, understanding why something is wrong matters more than being told what to replace. Do you find RV breakdowns tend to be more electrical than engine-related, given how much equipment travels on board? And for the rest of us, is there one habit or check that prevents the most common roadside problems? Curious how you approach diagnostics when someone is stranded and can't get to a shop.
Hi Isabella, thanks for the great questions. In my experience, RVs present a unique challenge because you're dealing with both the vehicle and the house systems. Electrical issues are common, especially batteries, charging, wiring, and accessories. But mechanical problems can be just as troublesome if maintenance has been overlooked. If I had to recommend one habit, it's a full check before every trip—tires, fluids, belts, hoses, batteries, leaks. Small issues are much easier and cheaper to fix before the road. As for remote diagnosis, my approach is to ask the right questions before replacing anything. Sometimes with photos or a video call, you can guide someone through basic checks and even solve the issue without a tow. Of course, safety comes first, and some repairs need a shop. Thanks again for the topic! Antonio
The point about asking the right questions before replacing anything seems to be the real skill. When someone is stranded with limited tools, narrowing it down beats guessing at parts. You mentioned batteries and charging as common RV electrical culprits; do you start by checking voltage under load, or do you look at connections and grounds first? The pre-trip checklist idea makes sense because it turns a vague worry into something concrete. For someone who only knows the basics, which item on that list is most often skipped and worth checking first?
The distinction between checking voltage under load and inspecting connections and grounds seems useful, because a reading at rest can hide a weak battery or a poor ground. Asking questions first also sounds like it prevents the parts-guessing trap. On the pre-trip list, I'd guess tires get the most casual glance since they look fine until they aren't. Is there one check you'd put ahead of the rest for someone who only knows the basics?
Hi Michael!
Thanks for your questions! You brought up something I strongly believe in: good diagnostics are much more valuable than replacing parts and hoping for the best.
When dealing with electrical problems, I usually start with a visual inspection of battery terminals, cables, connections, and grounds. A loose or corroded connection can cause all kinds of strange symptoms.
Then I move on to voltage measurements, preferably under load. A battery can show perfectly normal voltage with no load and still fail when you actually need it. Voltage drop testing is also one of my favorite ways to find problems that aren't immediately visible.
As for the pre-trip checklist, one of the most overlooked things is tire condition. People often check tire pressure but forget about tire age, sidewall cracks, and deterioration. On an RV, where tires may sit for long periods, that's especially important.
I'd also add battery connections and charging system performance to that list. A few minutes of inspection before leaving can save hours of frustration on the road.
My philosophy has always been simple: understand the problem before trying to fix it.
And when someone is stranded far from a repair shop, that approach becomes even more important.
Thanks again for the great questions!
Antonio
