2018 Ventana LE - 4048 -- Water collecting in the Front Driver Side Storage Bay
Cory
After driving in a rain I have water collecting in the Front Driver Side Storage Bay.
Looking for guidance.
1) Does the door gasket need replaced?
2) Is water possibly getting in through the wires entering the box from the outside in the area in front of the drivers side wheel.
Pics attached
Thank You
d
We had a similar issues on our Concord in 2021. The door itself was not sealed very well. Removed the door and frame, resealed. Good luck.
check to see if door is tight when closed. Might need adjusting
Our leak was entering the driver's window and ended up in the compartment below it.
It was on a 2016 DS.
Hi John,
We are on our way to Gatlinburg. I will check this out when we get settled.
Thank You,
Cory
I found a rectangular opening, (about 1"x1") just behind the fixed portion of the drivers side window, which had a small amount of water in it. I cut out a piece of gorilla glue tape large enough to attach to the fixed window then cover the opening and secured to the metal frame past it. So far I've driven in a light rain and have been in a good downpore while being stationary and have not gotten any water into that storage bay.
Hopefully this has fixed the issue!
Thank You
