I have a 2022 Rockwood GeoPro G19FD single axle trailer that I tow with a 2023 Tundra SR5. I’m looking at purchasing a Camco Eazlift TR3 weight distribution hitch.
My estimated loaded tongue weight is approximately 750-775 lbs based on the factory hitch weight plus batteries, propane tanks, fresh water and front storage cargo.
I’m trying to decide between the TR3 with the 800 lb rated spring bars (model 48904) and the 1000 lb rated version ( model 48900)
For anyone towing a similar GeoPro or other comparable single axle trailer:
Which spring bar rating did you choose ?
Have you noticed any difference in ride quality between the 800 and 1000 lb rated bars ?
Have you experienced a stiff or harsh ride with the oversized spring bars ?
Would you recommend the 800 or 1000 lb spring bars for my set up ?
I’d appreciate hearing about your actual experience
