Problem MH handles terrible with tow vehicle
SLNewbies
HELP……we are new to RVing. I’m the wife 1/2. We retired & want to travel with our pets. We bought a 2004 Winnebago Sightseer (with Workhorse P32 chassis) to see if RVing was for us without spending a fortune. MH is in great shape inside & out. Had it inspected by RV business/tech & only recommendation was new tires. Husband is retired new car dealership ASE certified automotive technician. He went over the MH engine & drivability workings front to back. He decided since getting new tires to get new shocks & airbags & alignment. MH drives & handles great w/o tow. I could drive it all day without feeling stressed.
Now, add tow vehicle & it’s all I can do to keep it in my lane. On a recent trip I drove it a few miles & was stressed out to the point of panic & tears. Husband took over & can drive it but it is a handful & unpleasant even for him & he’s a very experienced driver.
Flat tow vehicle: 2021 Jeep Grand Cherokee limited, 4x4, had tow package with braking, light system, etc. professionally installed. Tow with a Blue Ox tow bar.
QUESTION: Common sense tells me the tow vehicle is the problem, maybe too heavy for the MH?
Don’t know what to change. Different MH or different tow vehicle. I would appreciate any input from you more experienced RVers before we make a change or throw in the towel all together.
Is the tow vehicle properly aligned, tires in good shape, not overloaded or unevenly loaded? Seems everything else checks out.
I might suggest renting a car trailer for a test. If that fixes it then different towed or trailer rather than flat tow.
If he can flat tow it shouldn't he be able to tow dolly it?
Your tow vehicle is too heavy. Max is 5000 lbs and that’s very noticeable on that chassis. A 3000lb tow vehicle is close to what is comfortable.
Empty your toad is already 4700 lbs and once you add fuel and any extras it’s going to be heavier.
The max rating is a sales point and uncomfortable towing makes sense.
Is the Jeep going into a death wobble? Do you have a rear-facing camera you can use to monitor the Jeep while towing it?
The only thing towing close to the maximum should do is slow you down and kill hill climbing. The vehicle should track just fine back there and not cause problem with steering. Have the tow setup looked at and check the braking system. Something is not right back there. It is not adding weight to the hitch, so it should not be affecting handling.
Consider that the frame is designed for a much smaller load than a class a Rv and is already not great handling. Now add a 5k extension that is very close to the overall length of the original vehicle.
I have towed this combination many times. It’s not comfortable at all.
I’ll leave safety out of the discussion since it was about comfort.
I have towed things most people thought uncomfortable. I did it because I had no other option.
I have done it so many times that I sometimes read posts like this and I need to remember most comfort comes from doing something until the fear falls away and is replaced by a form of comfort.
If that can't be practiced. Adjust equipment until you can deal with the results.
I personally have no desire to tow flat. I found myself in the middle of a cloverleaf while driving on fog slicked roads when the vehicle decided not to follow.
I equated that experience to the comments about the Corvair that destroyed a market. "Unsafe at any speed!"
I don't like riding peddle bikes, but would rather haul one around to see the sites while on the road than trust the towd to follow My lead.
