Problem MH handles terrible with tow vehicle
You don't have to leave safety out. It's got a 5000 lb tow hitch and is rated to pull it. Comfort as Kevin says is in the abilities and expectations of the driver. I pull that much with my Class C and in high winds it is a handful. But I have realistic expectations about how it will handle.
Along the lines I would research what people have done in the past with this model MH as I have with my C and look to spiff up the suspension and make some changes to the alignment perhaps. Don't go by the factory alignment, find a knowledgeable alignment guy. It's not a new MH, in fact it's the same age as my Class C.
HELP……we are new to RVing. I’m the wife 1/2. We retired & want to travel with our pets. We bought a 2004 Winnebago Sightseer (with Workhorse P32 chassis) to see if RVing was for us without spending a fortune. MH is in great shape inside & out. Had it inspected by RV business/tech & only recommendation was new tires. Husband is retired new car dealership ASE certified automotive technician. He went over the MH engine & drivability workings front to back. He decided since getting new tires to get new shocks & airbags & alignment. MH drives & handles great w/o tow. I could drive it all day without feeling stressed.
Now, add tow vehicle & it’s all I can do to keep it in my lane. On a recent trip I drove it a few miles & was stressed out to the point of panic & tears. Husband took over & can drive it but it is a handful & unpleasant even for him & he’s a very experienced driver.
Flat tow vehicle: 2021 Jeep Grand Cherokee limited, 4x4, had tow package with braking, light system, etc. professionally installed. Tow with a Blue Ox tow bar.
QUESTION: Common sense tells me the tow vehicle is the problem, maybe too heavy for the MH?
Don’t know what to change. Different MH or different tow vehicle. I would appreciate any input from you more experienced RVers before we make a change or throw in the towel all together.
It's likely nothing to do with your MH and more to do with how the Jeep is tracking. If it's wandering due to the angle of the tow bars or something in the casters (it may drive fine otherwise, but not tow well), the tail is wagging the dog. if you have 5k lb towing capacity (likely) the vehicles weight is unlikely the issue. Next time you get loaded out and have the toad hooked up maybe you should take it out and one of you follow in another vehicle to see if the Jeep is wandering about behind the MH.
As posted earlier, a 5,000 lb hitch does not mean the coach can tow 5,000 lbs. The 2004 Winnebago Sightseer comes standard with a 5,000-lb. tow hitch, though your actual towing capacity depends on your chassis's Gross Combined Vehicle Weight Rating (GCWR), loaded RV weight, and hitch rating.
The curb weight of that toad is about 4,800 lbs thats with nothing extra in it.
Overweight, alignment issues, coach sway issues are all a factor that can cause towing issues
Your tow vehicle is too heavy. Max is 5000 lbs and that’s very noticeable on that chassis. A 3000lb tow vehicle is close to what is comfortable.
Empty your toad is already 4700 lbs and once you add fuel and any extras it’s going to be heavier.
The max rating is a sales point and uncomfortable towing makes sense.
Dang…..I was afraid it might be that but hoping for a different answer or solution. 😏 Thanks for your response.
