Question Will a half ton V8 tow 7,000 easily up mountains in Colorado?
kborgs
I've got a 7,000 lb tow behind camper. I'm looking to buy a V8 half ton or 3/4 ton pickup to tow it. Wondering if the half ton is enough to get it up Colorado mountain passes easily?
Easily is relative, but I wouldn't recommend it if it's going to be a regular thing. If it's a one off, then you'd just need to take your time and have good brake controller which you can manually engage.
Vehicles are a sum of their parts.
Engine size, transmission, rear-ended gearing. And yes even age. It's not the age as much as the HP and torque that were available for specific engines for that year and model.
My Jayco was just under 7000 and it was considered a 3/4 ton truck model. I had a 1 ton so no problem. But I have seen some scary 1/2 ton lash ups out on the highway. Its not if it will tow it, it will. But will it stop it? Will you lose control in a tough handling/braking situation? I have towed lots of loads with my 1/2 tons over the years but not at speed and not up and down mountains.
Nope
