New Member, 2011 Thor Serrano 33A Inverter issue
mullerm1
While cutting out the bedroom Carpet I accidently cut some wirers just under the slide. Didn't cut threw but enough to blow a circuit, The the ceiling lights went out.
Head board, tv, closet light still on.
checked breakers All fuses ,nothing blown, could i have damaged the Inverter?
Thanks in advance
Welcome to RVForums @mullerm1. I doubt you damaged anything, probably just need to find the fuse on the affected circuit. I would imagine anything electrical is going to be protected.
Thanks in advance
I believe the ceiling lights (and the other lights as well) are powered by 12v. So if some of the lights are on, and some of them are not, then the problem would have to be a fuse or you cut the wire that feeds them.
