help replacing AC Belt '05 Dutch Star
IKay
Kansas
Dutch Star
Trying to do as much as I can myself. Yesterday the AC Belt broke I had thought it was a bit loose, but wasn't sure how tight it should be. Looking at the belt, it did not have any visible cracks or obvious wear. How do I install a new one? How tight should it be? I'm new to all this. Just bought it a few weeks ago, and right now just chainging fluids and filters. The oil filter and drain plug were both a real pain to remove! Someone put way too much torque on that filter.
05 Newmar Dutch Star 4024 8.9 370 Cummins
Spartan Mountain Master Chassis
If the belt looks good with no visible wear, why did it come off? Maybe it's not a new belt you need. Take a look at the idle tension pully (idler) and make sure it's not locked up. Also look at the A/C compressor to make sure it still turns. Maybe the compressor clutch is locked up? I doubt you have just a belt issue.
Good luck!! Let us know what you find.
On my coach the AC belt is seperate from the serpentine belt. The clutch isn't locked up. I had noticed a few minutes before it broke that it appeared to be kinda loose...I had just started the engine, after changing the oil. In just a few minutes it broke. Will they break if they are too loose? I've got a PM scheduled in another week, so I'll probably just leave it off and let them install it...since they would just have to remove it anyway...in order to install a new serpentine belt. Told them I want to play it safe and replace the serpentine. Will keep what is currently on as a spare.
Just covering all the bases! A V-belt may break and still look good. But in my past experience a serpentine belt will usually show cracks from age or heat and missing sections of the "ribs" before it breaks. They seem to last a lot longer. That's why the automotive industry went that direction and away from the V-belt. That and the load capacity of the serpentine belts is much higher and can run more accessories.
