- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
So as some of you know I’ve hade the DEF system blues since Thanksgiving and I finally had my third visit to a Freightliner shop today. First I want to say that the good folks at Sacramento Truck Center really understand good customer service and they went out of their way to keep me informed and help me understand whats going on with this thing.
This time it was the DEF pump. Testing showed it was putting out only .5 psi. I neglected to ask what it should be putting out but I’m certain it’s a lot more than that - probably 100-150psi. So they replaced it and the coach is back in service. And while I’m pleased of course, I’m still not confident in the reliability of the system, and with so many component failures I’m left wondering what’s next.
But a couple lessons learned:
DEF filter - I’ve always read and been told that this has a 200,000 mile service interval. But that was misleading. That’s for trucks that do that kind of mileage in a year or two. Detroit says 3 years max. Mine is approaching 6 years old and I can imagine that in 3 years the paper can degrade, and as much as DEF likes to crystallize, I can easily see it getting loaded with dried urea, especially in a low mileage vehicle. So this is going to be an ANNUAL service item for me from now on and Im carrying one with me. It’s a simple job wit easy access. My part number is 5303604 and they are readily available. A cheap chinese knockoff goes for $11. A Bosch item $40, Cummins $100. Take your pick.
DEF (doser) pump - so this was the faulty part this time, but maybe it went bad fighting a constrictive filter. It’s still under warranty so FL picked up the tab and unfortunately the bad pump had to go back to FL for Sac Truck to get reimbursed. I wanted to do an autopsy on it. But no worries - they go for around $300, not a difficult job, and I’m putting one of them in stock too. My part # 4387304RX.
DEF Header - tested ok this time. It’s the third one on this rig, including the original. It was replaced in Oct 2018, and Nov 2020. I’m tempted to put one of these i stock too, but because they go for around $900, and because they are under continual revision (gen 6 now?), it seems to me that a spare could quickly become obsolete and a regrettable investment. That and my emissions warranty runs three more months. After that, maybe. Part# A04-28402.
Having spares is all well and good but it won’t get you out of derate. You need something that will clear emissions codes for that - not just a good code reader that clears codes. I have the OTR blue tooth J1939 code reader and a one year subscription. The package was $600 and I’ve heard conflicting opinions on whether or not it will clear a de-rate. My best guess from all the sources I’ve consulted is, yes it will, but only after the problem has been resolved. It probably wont buy you time and clear your derate if the repairs haven’t been made. Another option is to spend $1200/year on In-site. But both of these are somewhat expensive insurance and I don’t think I’ll re-up with OTR unless a problem presents itself that will likely be fixed OTR product AND no cheaper alternative exists.
So this is my attempt at a pragmatic approach in dealing with this problem. Given the complexity of the system and the fragile nature of DEF, I don’t see the problem going away, and I don’t see any relief on the horizon from policy makers, as needed and appropriate as that is. Mean time I’m going on a 6,000 mile trip before April 29 when my warranty expires and give it a chance to fail again while it’s still on FL’s nickel. I’ve charted FL service centers along the way and I’ll always know the location of the closest one. Best I can do for now.
Happy travels,
Rich
Happy travels,
Rich
