- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
It looks like the ME-BMK is 500A/50mV if that matters.
Thank you for that explanation, Chuggs.If you run a blow dryer, or a microwave, on inverter...you’re pulling more than 100A.
i have measured over 164A coming off my battery bank while doing certain things... So, a 100A shunt would not be ideal.
Question, if not running solar is there any advantage to the Victron BMV-712 vs ME-BMK.
I sent the data (that I had compiled over the last couple of days) to the manager of the store I bought the batteries from. He in turn, sent it to then manufacture. This morning I got a call from a representative of Crown Batteries. I'm not going to say he was rude, but he was quite direct and through a barrage of quickly asked questions, he determined (in his mind anyway) that the batteries were damaged because I was charging Flooded Acid batteries on the AGM setting.So yes, I turned the shore power off and then turned some lights on/off until I found the 20 amp draw I was looking for. (I suspect the inverter was 5-6 amps by itself.) I took a battery voltage reading off the meter, and then came back 4 hours later to take another reading. It' was just math from that point on although I'm going to go back down in a few minutes and get another reading as 4:45 will be the actual 6 hr mark.
Bad batteries?
The other part of this story is that the batteries were in my previous coach, and the charger was set for flooded acid batteries. When I sold the coach, i moved the batteries to this coach, and they were only in this coach for 3 weeks. During this time they did nothing except sit there on float mode.it’s a give or take...too much current you erode plates prematurely, ....not enough and you allow sulphate deposits to remain on the plates, robbing you of storage capacity. I’m not a battery engineer, somI just try my best to follow they mfg. settings.
Yeah, I guess that sounds a little contradictory, doesn't it?In your first post, @Jim, you said you bought the batteries for your solar conversion project but now say you removed them from your previous coach. How old are these batteries?
Perhaps, but again, I doubt it. We were in a "rehab" state with the coach at that time so the coach remained stationary and the batteries never saw any use. They remained connected to shore power and should never have discharged enough to need the inverter/charger to "catch up".In your first post, @JimI'm now wondering if the charging system in your previous coach was actually keeping them properly charged. If not, it might only take a relatively short period for them to sulphate up. Because of their large capacity, the undercharging might be disguised until serious damage was done.
