110v issue
Neemer
Crayon Eater
Virginia
DSDP 4326
ISL 450
During the trip to our current location, the 110 outlets in the bedroom quit working, and the central vac is also non responsive. I suspect it’s a GFCI issue, but I can find only one GFCI outlet. The “book” says there is one in the kitchen and one in the bathroom. I find none in the bathrooms, although there are two in the 110 panel with floor heat labels on them.
The outlet behind the sink in the half bath, does it have a reset button?
Other end of the string should be the outlet under the over counter cabinets??
Thanks @Neal You set off a scavenger hunt that resulted in the discovery of the hidden GFCI. We are back in business.
Glad you found it. It may help others to know where you found it if it was in a different location. The GFCI hunt in Dutch Stars seems to be a common one.
It was inside the medicine cabinet in the half bath.
Been there, done that. Actually had to replace the GFCI in the half bath. Kind of a pain to do. I have also had to replace one in the basement where the awnings are plugged in. I seem to have had a bad batch of GCFI’s which really seems strange. No problems since I changed them out.
