Question 2008 Damon Tuscony 4072
johncornelius
Canton , GA
Looking for help finging a heater control valve and actuator. This is for the Dash Air (Cabin Air).
The actuator has a three wire connector. The actuator looks identical to one made for several cars. GM, Toyota, VW. The valve has two 5/8" hose outlet and inlet pipes.
I found one at a RV salvage yard and they want $500.00 for a $50.00 part.
First, welcome aboard!
Second, guess they can charge whatever. On the flip side, it may sit there forever.
And, it probably is the same. RV manufacturers use as many off-the-shelf parts as they can. I’d buy one that looks identical and go from there. You can always return it if you find it won’t work.
