Bathroom Faucet Info?
DKRITTER
Haslet TX
Dutch Star 4318
Cummins 450hp
2022 Ford F250 4X4
We have a 2013 DS and the faucet in the back bathroom has begun to leak at the base very slightly. Naturally we are away from home. I need to run to HD or Lowes and get a cartridge or 2.
As far as I can tell there are no markings on at all. Ran thru the black box and didn't see any paperwork.
Does anyone know what brand the faucet and/or cartridge is?
I replaced all faucets except kitchen sink as that one is fine to me. I used Moen and they are simple swaps with 500% improvement in quality. Just look under sink and take a picture if needed to review connections.
That's the Plan B
I have replaced the cartridge on the past and found the part at HD. I have had good luck with finding plumbing parts on the road.
I need to swap out my bathroom faucet. I've been putting it off because I know I can't "get into" the cabinet and I know my neck will NOT turn enough to look at the connection(s) beforehand...SO, either I have to hire a very little person (had to do this on some boat projects...seriously) or it needs to be done by feel. Can anyone share their process with me for changing out an RV bathroom faucet with a relatively small vanity? Thanks in advance ?
All - If you take the valve guts to HD or Lowes, they should be able to match them up with the parts to work. Yes, the space in main or even rear bath is small. I think I could do it, but not worth trouble. I would get new guts. Based on model of coach, Newmar can tell you what brand it is, and might send new guts for free via mail. I would give them a call to see.
Success
I shut the water off, and took the faucet apart. The little Red/Blue button comes off first.
Found the cartridge at Home Depot it is a Danco # 89902
Newmar? Send parts for free? That’s a knee-slapper! :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
Yeah...I'm not trying to repair the faucet (because it works just fine). I'd like one with a higher neck. So replacing is the only option. I'll just have to start "feeling" around and dive in. Hmmm...that statement usually costs me double ?
2 things kept me from upgrading;
I'm cheap and I'm not a contortionist.
Well, Itried to remove the aerator in the bathrom to clean it. There was a divot in the center, so Iinserted a quarter, thinking it screwed out. WRONG!! It broke off. I guess it saves money to use a faucet without replaceable aerator. It is plastic. New faucet now needed, - and water softener. Arrrghh! Btw faucet still functions fine. Just don’t like broken stuff.
