- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
In the summer of 2018 I decided to configure my Class A Motorhome guided by @Chuggs to be able to run the front AC on solar. With 1800W of solar on the roof and a 100A Victron 150/100 tr solar charge controller already installed I was ready to be the guinea pig for one of Charlie's next inventions. I installed a 3 position switch near the circuit breaker panel that allows the power for the front AC breaker to source either off of shore power or the inverter. The inverter being powered by alternator + batteries with solar providing the current for the batteries (charging while use). One item required to make this happen was the installation of the Micro-Air EasyStart. First off, installation does not void or affect the Dometic warranty. Per the Micro-Air web site I found an installer not far from me that did the work. It wasn't that expensive to have installed but did take some time for various reasons (he bumped some dip switches which took a call to Dometic to sort out) but also a learning cycle you have to put it through which is 5 cycles of a 2 minute AC run followed by a 5 minute off interval. The placement wasn't ideal by the installer but it worked, Charlie installed on his and found a much better way to do so and maybe if he remembers how to install this he can reply with the instructions for others to follow as I sure don't remember. I followed Charlie's instructions and installed on my 2nd roof air conditioner and it went very smooth, took about 30 minutes and wasn't hard at all.
Prior to using the Micro-Air EasyStart such as if being powered by your gen you would hear your gen load up with the AC spikes with the startup load. With the EasyStart you don't get that startup spike of around 120 amps so the gen doesn't even load up and for this reason you won't hit low battery cutoff (LBCO) in a solar powered AC scenario. They are amazing and when your 50A coach is connected to a 30A shore power setup you most likely will not load shed. I was able to run both AC's just fine on 30A among the other items in the coach.
Check it out. Great thing to install for your AC's for various scenarios.
EasyStart Breeze RV AC Soft Starter for RV Air Conditioners
EasyStart Breeze technology reduces RV AC startup current by up to 75%, enabling RV owners to run their AC using a portable generator.
www.microair.net
