- Dec 27, 2019
- Virginia
- DSDP 4326
- Freightliner
- ISL 450
- 2023 Winnebago ERA 70A or 2016 Lincoln MKX
This has been an intermittent issue for some months now. My heat pump units appear to be getting fed some bogus temperature inputs from thermistors. It is most evident in my middle unit. It will be 70 deg inside, but the KiB display indicates a much lower temperature. The indicated temperature may begin to climb up to the correct temp, only to plunge back into crazy after a few minutes or hours.
My front unit will prematurely stop as if it has reached its set temperature. When I look at the control panel, it’s giving me the hourglass symbol as if it is trying to figure out whether it should start the unit or not. Inevitably, the unit will re-start only to cycle through this routine again at some unpredictable point.
At other times, it works fine.
I think this is a KiB issue. Sound familiar to anyone? Any quick fixes I should attempt?
