Buly
RVF 1K Club
- Nov 3, 2019
- TGO Titusville FL
- InTech
- In-Tech Dusk travel trailer
- Aluminum
- Lexus GX460
Thank you. Thank you so much. I really need some.Valium may help?![]()
I will agree that satellite is definitely not necessary if you have enough bandwidth from the Internet to stream content. Itās cheaper and the best part is you can watch what you want to watch when you want to watch it. We went streaming only and locals off antenna about 7 years ago and never looked back. You can go as economical as you desire on limited choices for streaming or get anything and almost everything (some you canāt get on satellite) so no drawback there. The only reason not to do this is if you are going to be in areas where sufficient Internet connection isnāt available but then even that has multiple possibilities nowadays via satellite so you have to set your priorities I guess. I have gotten really spoiled about not watching ads, sure I used to time shift on DVR to avoid watching but now without having to do anything and the show plays from beginning to end is perfection! Good luck with whatever you choose!Hello everyone, probably not a new question, so I apologize if this is old hat. Just started full timing in a 2022 Keystone Avalanche. This is our 3rd rig. We just hauled it 1937 miles in four days, with a 2021 Ram Cummins Tradesman. Wife is already missing her Direct TV Chanelās. We are a previous Direct customer with our account in āsuspendā.
Now the question. Should I go thru the effort of adding a satellite dish to the RV or do a stand alone? We still have all of the equipment from our previous household set up.
