Tankercharlie
- Sep 27, 2021
Call or send a question to: questions@wifiranger.com Their tech support seems good and responsive.How to set up Wifi Ranger Denali / Spruce 2022 London Aire
There is an update out for this system. Search for Ranger and see if you can find it. They may have to push it to you. There is a fellow on here who represents them some way, he can advise you on what you need to do.
We don't maintain field service staffs but most RV dealers and/or mobile technicians ought to be able to do what you want.Do you know of any Wifi Ranger dealers or service representatives in the Minneapolis-St. Paul area? My router recently died and I may need to replace it. But it's also possible there's a short in the cable and the router is fine. I'm not smart enough to diagnose it or repair it myself. Any suggestions?
With all due respect, yours was wired into a step-up transformer (12V to 24V) not a step down one. And those aren't used in the newer Converge product line.First check the fuse on that circuit, mine was plugged into a 120V outlet, so it may have popped the breaker, just reset and see if it comes back. If that aint it, again, mine was wired into a step-down transformer, so those connections might have worked lose, again, with power off, just wiggle the wires and make sure everything is tight. THEN, if still not working, call Newmar and see if they have any local ma\obile tech they recommend in your area, then call one of them, they should be able to diagnose the issue. If the lights work, it's on, if the lights are off, it's not on.
