Question Jacks leaking fluid
Busboy
I have a 2007 Newmar RV my right front jack is leaking fluid as I was lowering jack. Where is the reservoir to replenish hydraulic fluid ?
In my coach it's near the generator
What model is your coach? In my Bay Star, it is in the engine compartment on the right.
should be up front, near the genny as stated above, probably on the passenger side. Looks more like a box than a hydraulic tank, probably has some oil and dirt on top.
Is there a label on the reservoir? I'd hate for someone to tell you what's in theirs and it's not what's in yours. You typically shouldn't mix but use whatever was in there. If you can't find the info I suggest contacting Newmar and they may be able to answer it.
its either regular hydraulic oil or ATF, but as Neal says, you shouldnt mix them. Pull a sample and it should be obvious. Also you could dig up a HWH manual for it on line (just saw one here a couple days ago), and it will tell you.
Not all jacks are HWH. Mine are not.
Equalizer
