- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
So here’s the DSS:
Designed for Spartan (Shaw Development) DEF heads, but will work with Freightliner and now included at the website is the correct connector so that you can build one of these, soup to nuts, from sources found at the website. Be advised that with the simulator in place you can go merrily on your way (after code re-set) but will need to monitor your DEF level manually and keep your tank adequately full or you’ll create other issues which will lead to de-rate. This is not a system delete, or system by-pass device, it is a DEF sensor (level, temp, and quality) by-pass device. The system will continue to work as designed and will still require DEF. Nuf said on that?
Also be advised it WILL NOT work for pre 2016 Freightliner systems. My coach is a 2016 but the chassis was actually built in 2015 so it has pre-2016 emissions, including a physical float and no qual sensor on the DEF Header (Freightliner’s term - Spartan calls it a DEF head) and is not an electronic, digital, CANbus (whatever) type unit, so the DSS is not compatible. I bought the parts to build one before I figured this out and ended up selling them at a small loss just to get rid of them and because at the time the parts were back ordered and folks needed them.
So, thats the story on the DSS. As to all other things diesel emissions related, I do think it would be nice to have a diesel emissions forum, as I noted on Neal’s current thread about his DPF issue, and maybe this will inspire the beginnings of such a forum, but for now this post will have to remain in residence on the Cummins forum (or where ever it gets moved if there is a better location that didn't occur to me).
On another note I use OTR Performance ( OTR Diagnostics | Professional ) diagnostics which allows all kinds of emissions interactions, and I was a beta tester on the new system upgrade. Fun stuff!
I also just purchased the Diesel Laptops handheld unit ( Diesel Laptops Handheld Heavy-Duty Scan Tool with Regen ) which I will review once I have it. I reviewed a couple other code reading/scanning devices that provide live data on a phone or tablet in a previous thread.
So I hope someone finds this useful and if it starts a new Emissions Forum, all the better, because I see a lot of emissions questions and problems, scattered about on various forums, and Im sure I miss some. Likewise when I have my next emissions dilemma (note when, not if) it would be nice to have a specific location to discuss it.
All for now,
Cheers!
All for now,
Cheers!
