- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
I have a very small leak somewhere around my kitchen vent. I’ve found a small amount of water on the floor a couple times, about equal to a melted ice cube, and never made the connection to a leaky roof vent until we spent some time on the North Coast in heavy rain for several days. Then it became obvious. A small but steady drip from the vent. Light rain doesn't make it leak into the coach - I guess the insulation has been soaking it up for the most part.
I removed the decorative wood grill and the plastic interior surround during a nice heavy rain, found a lot of wet insulation, and was able to watch water slowly leaking in on the front edge of the vent housing. So I know where the leak is. I removed the wet insulation (thankfully no mold or mildew) and have been waiting to do the repair until I had a week or so of sunny weather so I know its dry inside and out.
What I don’t know is whether I should try to remove the generous portion of factory sealant first, or just add to it around the edges hoping that gets it. I don’t know how I would mimic the factory sealant job so removing and re-doing it wouldn’t look the same but it would probably work. Another option is paint the entire seal area with rubberized RV roof paint - I have some of that on hand as well as a couple tubes of dicor.
So the big question: What would you do?
