Need help locating the Solitude 345RES Nautilus P4 Water Control Panel, Part number 301-042-00007
YetzYak
Contacted Grand Design directly and they are out of stock. Also Contacted RecPro and they are out of stock as well. We also have a local repair tech trying to locate the part but so far no luck. We are full-time RVers up sheetz creek without water. Any help would be much appreciated
What is wrong with the one you have, i.e. can you or a mobile tech fix it?
Picture? Can it be repaired by a plumber or some expert? Weld or some other method?
That would be worth looking into. I will ask my tech if that is an option. The manifold is molded plastic and may be worth a shot if no replacement can be found
Wow…..GD can’t lay hands on it! I had always heard they were one of a few manufacturers that kept stock for such matters for their customers.
Good luck and as Neal stated, some handy-man engineering may be in order until one can be had.
