Morning fun changing a slide motor/drive unit
Rich W.
Retired Fire Chief
Rosemary Farm
Between RVs
Toadless
Small off-door-side bedroom slide on a ‘16 35’ Ventana. Really wasn’t all that bad. Took about an hour. I resisted it for a while but we have a couple trips coming up. When retracting the slide it moves in from the bottom first, then the top catches up, likely creating a bind which may have resulted in a broken gear. Either that or perhaps the controller needs adjustment.
So $804 later its back in service but Im still concerned about the way the slide comes in. I’ll physically assist it in until I can get it looked at by a slideologist. The drive shaft for the slide is so short that there is just enough room to loosen the trans-torque nut, so when reassembling, I installed the wedges into the nut and ran it down a couple threads in the housing before sliding the shaft in place. Make sense? Well pics will help. Cheers.
out with the old, in with the new
2B5CAB6E-AC6A-4436-BB44-59411730EF4D.jpeg55E85886-0204-4B6D-A4E6-32CC12A15CD0.jpeg79BCE669-DA5A-4FB6-BB43-E90BDB9E032D.jpeg
pre-assembling the trans torque nut and wedges
Old unit with the trans-torque nut loosened as far as it will go.
That's a lot easier to change out than mine was with the shaft going through the unit.
Yes I suppose I was “lucky” that it wasn’t one of the others that failed. This is clearly an easy one.
