holdiday rambler
  1. T
    2003 HR Endeavor need to repair driver side fuse panel door.
    As the subject says and as can be easily seen from the photo I'm including. The door sperated from the wood mounting.The wood I assume is made of plywood, is warped in the wall there where the hinges were attached by way of screws that are rusted. Apparently the previous owners did not address...
  2. T
    What Class A should we replace ours with?
    So here's our situation we recently finally got our wildfire settlement and we want to upgrade out of this old Winnebago that we have outgrown. Our budget is around $60,000 maybe a little more and we would like to find a diesel pusher with a leveling system and slide outs. This may sound a bit...
  3. C
    12 Volt Electrical Issiue
    Hello, I am having some 12 volt issues with my coach. I have a 2003 holiday rambler vacation with the workhorse chassis. So far this is what i have checked. I have 120 volt coming through the transfer switch and up to the breaker panel. Nothing from the 120v in the coach has power. So the...
