won't run
  1. F
    Used Sea Foam to Get the Generator to Run
    The ONAN/Cummins 4KY generator was challenging to start; if it did, it would not run for long. After reading all the threads here and elsewhere, this is what cured our problem - it may work for you. I poured six 16-ounce cans of Sea Foam ($8.49 a can at Walmart) into the full 55-gallon gas tank...
