‘91 F53 No Spark
Joe Rambler
SW Iowa
Fleetwood
Southwind
1991 F53
7.5L (460)
First time posting, I hope this gets to someone who knows old Fords.
I’m working on a ‘92 Southwind built on a Ford F53 7.3L (460). It ran fine last year, used mainly during football season. It’s been in storage through spring & summer. Son-in-law says he started it every month but getting ready to travel a couple months ago, it wouldn’t start. He replaced the old weak/dead batteries. Still won’t start. It’s getting fuel, no spark. Replaced original coil, cap & rotor, plugs & wires. Still cranks fine, insufficient spark from the magneto. Found a stray red wire in one of the black corrugated protective sleeves in the battery compartment with a female connector but haven’t been able to find a stray male tab that it goes to.
So, I have a few questions.
Why is it not getting enough spark from the magneto?
Any idea what this stray wire is or where it goes?
If I can get a mobile mechanic out to the RV storage farm, does anyone know for sure where to plug into the EEC?
Any helpful feedback will be vey much appreciated.
I believe your OBD1 port is close to the drivers side of the radiator, under hood.
You do not have a magneto, it's a distributor.
The red wire is probably the wire that should help the computer maintain it's memory. Fleetwood was famous for leaving that wire unconnected from the engine battery. Will not cause a no start problem.
Do you have fuel pressure? If not, there is a 30 amp fuse under the hood that supplies voltage to the ignition and fuel pump.
You could have a bad coil wire, distributor, TFI, EEC, etc.
At the age of you MH, you could have a electrolytic capacitor bad in the EEC. I just went through that.
You'll probably need a professional to trouble shoot the problem.
Richard
95 Bounder F53
It’s not actually a magneto on your ’92 F53 460, it uses Ford’s EEC-IV with TFI ignition. A few things to check:
  • Common no-spark causes are the TFI ignition module on the distributor, the PIP sensor inside the distributor, or the EEC power relay/fusible links. Weak or no spark almost always traces back to one of those.
  • With key ON you should see ~12V at the coil’s positive side. While cranking, the negative side should pulse. If it doesn’t, the TFI or PIP isn’t triggering.
  • The stray red wire in the battery compartment could be important. On these chassis a fused red wire feeds the PCM/EEC relay or ignition system. If it’s disconnected, the PCM won’t power up = no spark. Check it with a test light to see if it’s hot with key ON.
  • The diagnostic connector (EEC-IV/OBD1) is under the hood, usually on the driver’s side near the firewall or brake booster. It’s a gray trapezoid plug with a single-wire pigtail. You can pull codes with a cheap reader or just a jumper wire and count the CEL flashes.
I’d start with:
  1. Verify 12V at the coil with key ON.
  2. Test for pulsing ground on coil negative while cranking.
  3. Inspect/replace the TFI module (very common failure).
  4. Trace that red wire—if it’s the PCM feed, reconnecting it could solve the whole issue.
Just so you know.
The TFI on 460 F53s is on the fire wall, drivers side. Mounted on a heat sink.
Richard.00000
I had the same problem. Check your fuses. I have a 2016 F53 chassis and I have 2 fuses in the main fuse panel related to ignition. I found one blown. Once replaced it started right up.
I have had numerous cases where the rotor was bad even a new one.
