02 Sunstar 21' motorhome VW
fluidray
Hello,
I recently bought a 2002 Itasca Sunstar. I am trying to replace compartment latches and they are different from what is commonly used currently. Does anyone have a source or a DIY fix to adapt the new (shoulderless) latch
Welcome to RVF, @fluidray; glad you have joined us. Would it be possible for you to post a photo of the latch you are looking for? That would help us help you, and get you pointed in the right direction. Many of the latch mechanisms come from the same manufacturer/distributor regardless of coach model.
Thanks for the quick reply Jim. The attached image shows the oem key latch minus core.
Sorry I didn't make that very clear.
The one on the right I purchased bc I thought it would be a direct replacement. But it is too small diameter. I need a spacer/housing to go around the new lock bc it is smaller diameter. A complete assembly I think would be preferable. At this point I'm looking for any solution.
Try here...
They show thumb-turn latches in several diameters; 5/8", 7/8", 1-1/8" an 1-1/2". There may be some other sizes on previous pages at rvupgradestore.com. They stock a lot of hard-to-find RV parts.
Welcome from Georgia!
Try here...
I contacted them and it appears they all share the same diameter body. It is the length that the different sizes represent. I just find it hard to believe that it is such a rare lock. I'll look in industrial applications?
Can you find any identifying marks on the existing latches? If you had a brand name, model number, etc. it might help in tracking down a replacement. Also, have you tried contacting Itasca to see if they could help you identify the manufacturer/supplier? Like you, it is hard to believe that these latches are rare items.
Good luck.
I'll check more closely for any identifying marks. The local Itasca dealer rep was trying to track down a part but I haven't heard back as yet.
You could cover the hole.
use a key lock in the hole, and drill a couple holes that can take the twist locks on the side of door.
Cover the hole and use solenoid catches instead.
All depends on how long you have to look for the replacement I guess.
Thank you I'll keep that as an option.
